Harry in Ky
- Location
- Central Kentucky
I don't get into these all that often and I can usually figure out what goes where. This time not so much. We have a "no PTO brake" problem. I have the tractor split, and the hi/lo clutch out on the floor. I'm air checking the brake and clutch through the tubes now exposed. There is machined surface on the clutch housing where the hi/lo clutch housing mates up and the oil passages meet for hi, lo, PTO, and PTO brake oil supply. The oil for clutch pressure and brake pressure flows through passages in the hi/lo housing into the two PTO supply tubes. (Items 12 and 14 on the diagram below)
Pressure line (12) is self explanatory. It's brake line (14) that has me all turned around. It meets the back side of the machined casting mentioned earlier and somehow must connect to the hi/lo housing through a drilling in that mounting surface. I guess my question is mostly about item 16 in the drawing. It appears to be the connection between line #14 and the port in the hi/lo housing. It doesn't seem to exist in this tractor. Brake supply line 14 comes up to the back side of flange but has no connection to anything at this point. There is a hole through the flange that matches the supply port in the hi/lo housing, but I see no way for the line (14) to seal to anything. Where does item 16 belong, and how does all this fit together? The hole in the casting is only 5/16" so no room for item 16 to fit through even if were there. I'm lost at this point.
