Update. Hello guys. Been cranking on this dude the last couple days and no start yet. Went through the wiring, replaced all the terminal ends, got a new four wire key switch with key start, and once I figured out the alternator wire going to one side of the ammeter should be by itself then it all fell into place. Pulled an old battery out of the pickup and it didn't have enough to crank it very long. Bot a new battery last night and cranked on it and it was smoking by the solenoid. Changed out the positive battery cable and the next one was getting hot and smoking too. Cleaned up the terminal on the original one and it worked ok without getting to hot or smoking.
Added another battery with jumper cables and cranked away. It would try to fire. Played around with moving the distributor to adjust the timing and didn't help much. Checked the wiring and firing order and points. I have two inline spark plug test lights and I'm getting spark to the distributor and spark to the plugs. It is hard cranking and cranks like the timing is a little retarded but a couple times it took off like it was going to start.
Pulled the needle valve out of the carb and got good flow. Tried it at 3 turns out and 4 turns out with no effect and left it at 3 turns open. May end up pulling the carb and checking it out.
Looked at the book and realized there was no spring on the governor. Must have gotten lost in the shuffle somewhere. Is this spring a particular caseih part or will one work from TSC or Ace? I've looked around and don't see a spring anywhere. There is a pic up above of the governor and I'm not sure where the spring go. Thanks.
