I don't know what to say now guys. Thought I might have all my issues fixed. Got the gasket for the 2606 C-221 engine filter housing, put a plug in the oil galley under it, and put it back together. Cranked on it a little without the coil wire to see if it would pressure up and it didn't. Put the wire back on, choked it, and it fired right off. Just as it was starting to rev up, the oil pressure came up to 40 psi, I pushed the choke back in immediately, and it died. Don't know if it died because of the choke or because it tightened up. Then it wouldn't hardly crank over and my old battery was running down.
Today I go out and it won't hardly crank over. Pulled the plugs and squirted oil in there. Looked in the cylinders with the scope but couldn't see much. Tried to pry on it underneath and couldn't get any leverage but it wasn't free. It would move just a little with each try of the starter but it was getting hot. Pulled the starter and it ran ok being out. Tried to pry on the ring gear but couldn't get much leverage.
It ran started and ran ok the other day. I guess I did something to make it tighten up and stop.
Any ideas? Thanks.
Any ideas? Thanks.
