275 - can't find correct lower radiator hose
petebert
Can't find a lower radiator hose for my 275. Low serial number, starts with 230. Local massey dealer had both hoses listed in the catalog, neither matched. Seems like the angle for the bend was wrong. The current numbers in the agco catalog are 579773M1 and 534180M1. They both show 1.656" which matches my necks. If you simply google "massey 275 radiator hose" you'll find some that visually match but they're listed at 1.5". My water pump neck is 1.61" with a 1.68" lip. My radiator doesn't have much of a lip and shows 1.63"
I went ahead and ordered 194737M1 which shows at 1.5" but appears to have the correct angle, so we'll see what happens there. I also ordered an old paper parts book, curious to see what numbers it lists. Maybe it will cross reference to something else?
I can't find any stamps on the motor block but I found a sticker on the intake that says A4-248 which is the correct motor. Also found a stamp on the water pump 37711710 which when googled comes back as water pump base for 265/275.
Pictured below is my old hose next to the new ones
