3 point lift
Yanmar YM2210B, changed hyd oil, cleaned filter screen, now 3 point lift does not work? what may be wrong?
trapped air in the system.
And what did you clean the screen with? Typically, diesel fuel works best with a soft bristle tooth brush. Other chemicals 'could' melt the plastic olefin mesh and prevent the fluid from flowing. Thus, the filter is now trashed.
The olefin mesh flows only in one direction. It's tiny little pores like this under 10X magnification.
I doubt the screen is your problem, however, just looking at the parts drawing it would look like your screen is up pretty high on the transmission case. If it is above the dipstick level then yes, you could pull, it, if below, you could not without loosing your fluid or at least a portion of it. I would lean toward figuring out how to get some fluid in the suction line going to the pump. I agree with bmavericik you are likely air locked.
Ok, thanks so much for your help, I am also thinking it has air trapped in the system, I will work on that
Again thank you
