Per an earlier anthology....I removed the hydraulic pump because it was leaking out the front seal a bit. I did all the firsts...removed the front carriage, the 2 side fittings, the upper banjo bolt fitting and the drain line. All of it loads of fun!
I had a pump off of a salvage tractor that was supposedly not leaking and working well so I took a chance without doing anything to it and put it in and put everything back together. Started up the tractor and I don't believe I am getting oil to the pump...the manual destroker will push down the valve so I know the main valve moves.
Could there be an "air lock" or something like that? If so, how and where would I bleed it out? Thanks.
