3020 Rear Weights
ajhbike
I have 2 sets of A3404R rear weights and I cannot figure out how to mount them:
-Part numbers on the inside?
-Raised flanges on the outside?
-A or B holes?
I am about ready to roll them into the marsh
It's not rocket science. You already have bolts in the wheel casting to receive the first weight. You already have bolts in the first weight to receive the 2nd weight. There are timing marks cast into the weight and the wheel casting to get the first one oriented correctly.
I read an old post about using a cherry picker and a long threaded rod and it worked well. All are on (after forgetting to put the 2nd set of bolts twice!) and great fact about the timing marks.
That is the mark. It will be apparent as well by the “twist” in the middle of the weight you have 2 options one will have enough relief to fit well around the adjustment bolt and line up with the holes that’s how I figured them out. You have it facing the right way. A is the correct mounting hole and like said above b is for the next weight you are just missing one bolt
