340 hydraulic issue
Pete7
Ive been chasing a noise in the hydraulic system for
awhile. Comes from the pump. Ive changed filters and
fluid a few times. But I still get a whine from the pump.
The hydraulics work fine, go up/down, have good power
and dont seem slow. This farmall 340 has the engine
driven pump. I hear the whine whenever the tractor is
running. If I operate a lever the noise stay. I hear the
safety pressure relief valve open at the end of a cylinder
stroke.
Ive checked for suction leaks by replacing hoses, clamps
and o rings at the pump to manifold connection. I even
split the tractor to replace a darn o ring inside it that
connects to the internal suction tube. Worked myself silly
checking for a suction leak so Im fairly sure that isnt the
cause of the pump noise.
I checked to make sure the valves were on the dual
setting and not anywhere in between.
I cleaned the regulator control orifice and even drilled it
out to .040. Checked the safety relief valve visually. To
check if the regulator valve ( unloader) was really
dumping pressure I re-routed the discharge hose to the
reservoir to a bucket. Got half a bucket of fluid in about
half a minute. So hears my question ( finally, right!) Can
the regulator valve be only dumping some but not all of
the fluid it should.?opening partially? I could drill ithe
orifice out a little more but if I go to big the system wont
go on demand and that thing costs$$$$.
Hi Jim. I appreciate your help. Yeah, it might very well just be something Ive got to learn to live with but, my neighbors 340 is quiet and this 340 was ok till it got a replacement pump. So maybe the replacement pump is noisy.
The thing is, the pump is quiet if it hasnt picked up a prime yet. Once it primed the noise starts. Not sure but this makes me think it isnt gear noise. Whats your take on it?
The hydraulic system does have a residual system pressure that is part of the pilot control, orifice valving. so it may have just enough added load to make noise. If it is not getting hot, it is going to be OK. Jim
