350 Ammeter Problems
(quoted from post at 13:09:40 11/13/23) Sorry, did not think I had to repeat what said in my first
reply where I linked the diagram there; I said it did not
have the preferred connection to power the start
button and told you where to connect it. Even though it
is not original as a ..charge light.. it was placed there
to do the same job as the diode as I explain in a later
reply. If need be print out the diagram and find a wire
or circuit between two points. Go to your tractor and
make sure you have a wire making those connections,
then put an X on it. Once you have an X on all the wires
on the diagram it should work correctly.
ot her done! Everything is working perfectly. Thanks for all the help!!
