chevypanel46
- Location
- Springfield, Tennessee
I’m sure looking forward to hearing from the very knowledgeable 350 Utility owners here. I've been using my ‘57 350 Utility with front loader and blade for driveway maintenance for 8 years now. Now...almost everything works well—it shifts smoothly into all 5 gears and main clutch appears to be working perfectly. I’ve never had to use the TA for any reason, but it appears to be operating exactly as it should (going into “lower gear mode”), but when depressing the clutch pedal while going up a grade the tractor will not roll backwards and seems to be locked in gear until engaging the clutch to give it a little forward slack to pull it out of gear. It does exactly the reverse of this in reverse gear on a downhill grade. Like “used red MN” describes in one of his posts
“Say you have piled some dirt with the loader and yourun the front wheels up the pile. When you push the
clutch in the tractor will be locked from rolling
backwards due to the one way clutch.”
So it appears the TA "one way clutch" is frozen up but I’m hoping it can be unfrozen without splitting her open. I’ve watched Doug Gingell’s YouTube video, “How to Adjust the Farmall Torque Amplifier”, and I’ve tried—and tried—to adjust the TA/clutch linkage but with no improvement.
-Strange as it seems, with the clutch pedal full down and the TA lever all the way to the rear (engaged) the tractor WILL roll backwards, but only as long as the TA lever is held there.
-After removing the 4 hole inspection plate I was pleasantly surprised to find the clutch assembly looking completely intact with what appears to be a good looking clutch assembly, good throwout bearing operation, and a healthy looking clutch disc.
-With the clutch pedal down I can easily rotate the TA clutch counter-clockwise (looking from rear to front) but not in the opposite direction.
-With the shifter in neutral and the TA lever pulled back I can rotate the clutch disc with my finger tips.
Don’t know what more to add, but I sure look forward to ya’ll’s good advice.
