I have a newer 4020 syncro split for a bad traction clutch. I knew it had hydraulic oil getting into the clutch housing but just assumed it was the o-rings on the actuator for the PTO clutch. Due to my lack of experience I did not remove the bottom cover and try to see where the oil was coming from before disassembly. The piston o-rings weren’t all chewed up but were a little stiff but now I’m wondering if the sea farther back is the culprit. Is there a way to see if that seal is leaking?
The traction clutch was dry but the PTO clutch had oil on it. The splines for the PTO disc the tube for throw out bearings were also wet.
