wore out
The line you found damaged carries oil FORWARD to supply the main hydraulic pump.I got no issues slipping in gear and everything shifts good it’s just the clutch don’t stop the tractor and holding the clutch and you rev it up it’ll go forward. But yesterday I went to crank it and found a awful leak someone had brazed in the past and the line crushed right behind the frame rail that runs From the pump at the front to the valve at the clutch so I pulled frame rail and got it out to change it today. Someone mentioned checking pressures could someone Tell me which ports do what and what pressure should be?
The powershift and PTO clutches and PTO brake are operated by the transmission pump built into the front of the transmission, much like a conventional automatic transmission pump.
There are 3 ports in the clutch valve and they're marked for clutch, PTO clutch and PTO brake. Pressure should be 140-160 psi when the function being checked is "active".
In addition, the shift valve on the RH side has about 7 pressure check plugs where the pressure to a specific clutch or brake pack can be measured.
