Fixingfarmer
Warning super long story I’ll skip some but friends have a B that the whole family has fixed up for the son with autism to take to the fair.
I wasn’t able to help till last week since dad had some health issues and I needed to focus on planting this spring.
Crankshaft was replaced because splines were not so good on it and the driving disk. I think the new (used) ones are worse but that is neither here nor there. What is relevant is they didn’t bother to time it with the mark on the crank and the mark on the cam gear
They got it together painted and it wouldn’t start. Since we are done I went over last night and we had gas pouring out the carb whole thing was full of fuel.
Pulled carb off my running B float problem solved till I get time to rebuild it
Still no start. Was shooting gas backward out the carb when and got the compression tester 0 both sides. That’s when l discovered the timing issue. To be clear everything ignition wise was fine that’s what we were checking last night and even would line up on one hit on the impulse mark.
But the compression issue was a dead giveaway as it ran going into the garage and rather well from the sound of it
Lined everything up like it should be but definitely shakes a bit.
It was converted to a distributor and is 12 volt I was going to go back with a timing light so there’s no more questions and align the impulse mark on the flywheel with the line on the case and while this is definitely overkill I should be able to get dead perfect on target.
How likely is it to smack one of the valves with a piston if it wasn’t timed right? Head appears to be correct I was debating borescoping it to take a peak but don’t really want to add fuel to their stress level. The uncle who was helping already feels horrible
Push rods look fine everything in the valve train seems to be behaving it lined up just like the book said when I rotated the crank to the exhaust open the marked tooth on the cam gear that I had been holding it up in the air was waiting for it when I had rolled it over first try couldn’t believe it.
The shaking is concerning but like I said I figure to time first then start looking around I checked the clutch side of flywheel to make sure it was tight…what else? Flywheel I suppose.
It also had every wire pulled off of it when I got there as this was somewhat frustrating to the poor guy. I can safely say there isn’t a fuse on the machine anywhere which we probably should remedy. We have a nice key switch though and was going to fuse the light switch it is equipped with 2 12 volt bulbs so I figured a 20 amp unless anyone says otherwise.
Old school points I figured a 20 amp as well and to keep them all seperate I seem to remember my harness on the late A only having one for almost all of it? But I’m too tired to go look tonight. I’ve not had any trouble running the loads I usually have off one wire from the switch on that single fuse but i usually end up with LED lights so I was concerned about the load a bit it appears there’s a separate light supply cable originally all the way to the starter I do usually like to make them run on switched power so if I had the road lights on and it’s daylight and I don’t notice the key shuts them off. We do make sure to at least have a red light here.
I also let the smoke out of the 3 wire alternator by hooking up the wrong wire to the exciter to add to the stress level. Hadn’t ever seen that happen before and was a little confused as exciter should be switched power…?!!? definitely was smoking and found a parasitic load after that when I was checking and had the negative cable off the battery so it’s getting replaced the other cables go to self explanatory things so I’m not sure how that happened chicken or the egg but I sure look like I caused it
I think that’s all the news it was a busy night and morning. Happy Memorial Day to All!!
Thanks in advance for any imput
