used red MN
- Location
- Coon Rapids, MN
Okay we’ll give this a whirl, it will either make your tractor run or smoke the wires. You didn’t answer my question about front or side mount distributor, but by saying the red wire goes to the coil on top of the points that tells me you likely have a front mount. Can you tell where that black wire is going off your alternator? It should have a connection back to your ammeter. Whichever post it connects to on the ammeter your yellow wire coming from the battery post of the solenoid connects on the opposite terminal from that. This should be the only wire on that terminal of the ammeter. The opposite terminal on the ammeter that the alternator wire is on is where one terminal of your toggle switch will connect to. Also in your photo I circled two yellow wires in red. If the eyelets on them will reach the ammeter terminal that has the alternator wire on it take that bolt out of there throw away the short yellow wire with the bare end. Sand and clean up those eyes and put them on the ammeter terminal. The other wire off your toggle switch will go to one end of your new resistor and the red wire going to the coil will go on the opposite end of the resistor. I am not sure what the deal is with your red wire at the alternator, it is not even hooked up. Where the side terminal spades on the alternator ever hooked up? I know there is a lot of wires on the one side of the ammeter but that is correct. That gives the ammeter the ability to show the discharge of all current loads and the charge from the alternator all measured against the one wire that goes to the battery. Now let the smoking begin!! I would make a light quick touch of the battery terminal to the post when reconnecting to check for heavy sparking/shorting after you have made the connections just in case you have some hidden variation in your wiring that I couldn’t account for. Also for gosh sakes, don’t wrap bare stripped wires around the terminals and smash them under a nut. Spend a couple of your shinny nickels and get yourself some crimp on wire eyelets and a crimp pliers. Soldering them on the ends of the wires would be best but I know that is a moon shot. If you have to move a wire off a terminal that you claim doesn’t need touched, to wire it as I instructed.. DO IT! I am providing you info of how your tractor should be wired to make it reliable and correct. There is also the possibility that you need a 2nd resistor in you red wire to your coil to increase the life of your points and coil. We can discuss that after you get it running.
