Ok. I started talking about this in another thread. I was asked, by another member, to start a new thread for this discussion. So here goes.
I completely rebuilt my engine. Running straight 30w oil, I get 60psi oil pressure. As the engine gets warmer, the pressure drops to below 5 psi at idle. I raise the rpm a bit and the oil pressure doesn't come up much. I've read all the other threads about using different weight oils. I think that I should have great oil pressure with 30W oil. I live in Colorado and use my tractor in winter. Anyway, I thought maybe I screwed up somewhere. I dropped the pan and plastigaged the crank and rod bears, with in spec. Pulled the oil pickup tube, pressurized it under water, no leaks. Checked the oil pump, which was rebuilt, all in spec. Oil relief spring and plunger new.
The only thing I didn't measure was the cam journals and block bore. I have a front distributor engine and can't find a new cam. I think this is the original cam. The journals are not black or scored and the lobes have nice peaks not rounded. The other thing I did change, I originally had a non proofmeter governor and I installed a governor that would run a proofmeter. The only reason I mention the governor is because it uses oil pressure to operate.
After all that, my question is "could the cam journals affect oil pressure when hot"?
I think the answer is yes, if like car engines. What can I do about it??
I have not found specs for the cam journals. I do have service manuals for the 8n.
I have not found a thread about the cam on any forums.
