Rich'sToys
- Location
- Southern MN
Just had the starter rebuilt for one of my 50's. Now when I step on the button, a lot of times it will just grind instead of engaging. May take several tries before it engages properly.
What I THINK is happening is--when you step on the button, it manually engages the drive into the flywheel while pushing the switch button at the same time. I suspect it's hitting the switch before the drive gear is fully engaged, causing it to grind against the ring gear.
I haven't pulled the starter back out yet, as it's a bear of a job for a 75 year old guy, but just wondering if there's some kind of adjustment or something, or is this something I'll have to live with? I was looking it over before I put it in, just to see how it works, but didn't notice anything that looked like an adjustment. Any thoughts?
