Crashfarmer
The first time I used the 861 was with my 3 point Bushhog mower and I wondered why it wouldn't lift it clear off of the ground but it'd just come up a little. I thought it was a pressure problem but I haven't gotten around to messing with it until now. Now I'm wondering why the lifting height is inadequate? It only comes up about knee high at the most. I noticed the position control reaches the lowest point only halfway down the possible path of travel. Now I'm wondering if it might have been knocked out of position inside somehow. I've thought about removing the lever so I can turn the shaft more to see if it will lift to its full height.
I know my 50 8N lifts a lot higher and the 861 should be close to that but it isn't.
It's definitely not a pressure problem, I put the boom on today and it lifted a Y-block Ford engine with the bellhousing, flywheel and clutch still bolted to it with no problem at all, Y-blocks are heavy engines! Our old 9N wouldn't lift a 302 using the same boom.
