I've had this tractor for 25 years and the piston and cylinder popped two attaching bolts when the lift went all the way up so fast after adjusting the draft. I just wanted to get it to go a little faster and boy did it, the lever was kind of tight and it went fast alright. On my 60 MF-35 I put a new piston and cylinder for the lifting of the 3-point hitch after breaking two bolts on the old one. Now that I have it in, I can't get the hitch to do anything. I checked the top where the tube supplies pressure to other equip (that I don't have) and when I turned it over it has fluid pressure coming out. I do believe it is something in the controls. checked the 2 arms that go down to the roller and they are both in front of it like supposed to be. Still the actuator arm does nothing. When I pull it back to lift, there is a click in the arm halfway up. Please I need help, the pump is supplying fluid, but I can't get lift to move at all.
