stateofidleness
Hi all.. I'm drowning in different wiring diagrams and kinda lost...
Here's what I have:
- 2 position key switch
- 4-pole isolated ground solenoid
- 1 wire? alternator (has an additional wire for "excite" i think?)
- Still using neutral safety switch
- 12v converted with neg ground
Current wiring is:
- 1 side of key switch has:
- key to a terminal block that has "S" from solenoid, ignition coil positive
- Lights and other gauge power
- Other side of key switch has:
- key to a terminal block that has smaller of the two alternator wires
Big alternator wire and big battery positive wire to left side of solenoid. Other side of solenoid goes to starter positive.
Neutral safety switch goes to "i" terminal on solenoid.
I'm not really sure how the key switch itself gets power. I tried a wire from battery positive to either side of switch, but seems like this would keep the lights "on" and drain the battery.
Here's what I have:
Current wiring is:
