Good afternoon gents.
I have a 630 that my wife inherited. when we got it, it was non running but a little tinkering got it going pretty well. I found after getting it going that the crankcase was filled with gas from a failed auto fuel shut off. I have replaced that setup with a normal sediment bowl and changed engine and trans oil. we have run it at two tractor pulls for a couple hours each time and both times have lost two quarts of oil, it doesn't seem to be leaking any oil and only smokes briefly on startup so I don't believe it is burning that much oil either. I have done some reading and found that there is a high probability that the gas took out the main seal on the first reduction housing. I have also read there are two square cut o rings that can be damaged by gas.
my predicament is there is a tractor pull coming up in a couple weeks and i was wondering if there was a quick easy way to determine if these o rings were damage. the tractor runs well with no unusual noises and has good oil pressure, right in the middle of the gauge. how big of a deal is it to pull the bearing housings out to check the o rings if that is the absolute recommendation? I would like to get this rig in the last pull of the year but at the same time if I run it with improper oil flow and mess the crank or rods up i would kick myself in the back of the head for a long time after.
so I guess my two questions are is there a easy way to determine the condition of the o rings, and if it needs to be tore down to replace the o rings and main seal how big of the job is that?
