FinallyFarming
G'day friends.
Today I am working on the 706 to replace the steering hand pump at the dash console.
I have the large IH Official Shop Manual for this tractor and tried following the guide, but it seems steps are missing so I'd like to ask someone who has done this if the manual is missing important removal information of if I simply am not understanding the procedure.
The IH 706 Shop Manual details the removal process as follows.....(summary)....
1). Clean the area around the pump
2). Remove the steering wheel
3). Remove the rear panel from the dashboard
4). Disconnect the hydraulic lines
5). Quote "Remove the capscrews and lockwashers holding the manual pump to the instrument panel and remove the pump from the tractor" (Page 677, IH Official Shop Manual)
Pardon me, but this is not all the steps required to remove this pump as far as I can tell.
Removing the pump ALSO requires removal of the throttle lever AND the Press Pin going through the throttle lever shaft which protrudes through the cover plate.
It is mandatory (I think) to remove this pin in order to remove the plate that the pump mounts to because there is no way (that I can see) to remove the pump from the rear)
So either I haven't seen the light and am confused, or the manual is over simplifying the process and leaving out important information. I will say up front that I believe the shop manual to be the authoritative definitive and correct source of repair procedures for this tractor so I must be incorrect, but I can't see it.
Any comments that would help me understand the removal process would be appreciated.
For illustrative use only to clarify my point about the information in the manual, I have included a partial screen shot of the steps in the manual for your review.
The manual is most certainly copyrighted and I acknowledge the owner of the copyright and do not in any fashion attempt any commercial use of this image.
And here is a photo of the back of the dash. There does not appear to be sufficient room to remove the pump from the rear.
And finally, here is the metal plate that has to be removed to get the pump out and the pin that must be removed to get the plate off.
Please tell me I am making this harder than it really is
Thank you kindly
Thank you kindly
