Centerline
I bought an 850 about 2 years ago and the hydraulics have been hit and miss as to when and if it starts to work.... but when it worked, it seemed to work fine without any noticeable issues...
Ive never had reason to try using the draft control, but the draft lever was definitely wrong, as it would go up vertically, and down parallel with the gasket, but not downward.....
its supposed to go downward for draft control and horizontal for position control.....
the last few times I ran the tractor, using the FEL, the 3pt lift hasnt functioned at all, but just useless iron swinging around back there......
so 2 weeks ago I tore it apart and checked things out and ordered all the parts I needed....
the pivot pin was worn severely so I replaced it (someone had swapped the pin end for end some years ago, as the hidden end in the lever was worn also)...
the piston seal had been replaced, but the leather back up ring appeared to be original and was hard and crispy and worn thru... or possibly had been sheared off as the piston was inserted into the cylinder...
im thinking that someone without knowledge or a book to go by had removed the cover and taken it apart to try and fix it by making adjustments, as the main spring yoke was tightened up about as much as it would go, and the turnbuckle was adjusted to try and get it to work better with the worn out pin, as it was quite far out of adjustment, both the [i:503bb2caf3]draft[/i:503bb2caf3] and the [i:503bb2caf3]position[/i:503bb2caf3] settings...
I got the cover assembly all back together with new parts and before replacing the cover, I took the pump off and pressure tested the lines to 60lbs, and which have no leaks at this time....
I took the VANE pump apart for inspection and found the shaft seal had worn a groove in the shaft, so I replaced the shaft, seal and bearing.... and cleaned the flow control valve. the vanes are moving freely in the rotor and were out against the walls of the cam ring.... there is no noticeable wear on the rotor, vanes, cam ring or end caps....
after getting the adjustments all correct and the tractor back together, the pump refuses to prime, even at max throttle...
there is no oil flow at all... Ive had the pump off and back on 5 times so far, trying different things, double checking my work and trying to locate the problem...
so im here looking for input from those who have had similar issues on why it wont prime up.... all the orings are new and of the correct size.
AND the confusing part...
when I took the pump off the tractor, I marked it with a paint marker so that I could get it back together in the same way it came apart...
the ARROW on the cam ring was pointing up in the direction that the pump turns, BUT the book shows it pointing downward in the opposite direction of the rotation.... I have tried switching the cam ring, but still no prime... which is the proper way for the arrow point? and where else to look for the air leak that is preventing it from priming.
thanks for any help you may be able to offer....
This post was edited by Centerline on 09/29/2023 at 06:54 pm.
