Danny Hogge
Just bought this 830 CK and the three point will barely raise the lift arms with high throttle. Then if dead head the remote up or down the engine strains as the pop off valve opens and the three point drops down. Also with the lift arms fully raised when I shut the engine off the lift arms drop all the way down.
Its full of clean Hy-Tran. Hydraulic are noisy and sounds as if its pumping a lot of air. With operation of lift in max raise
position and at high idle RPM.
I want to suspect the pick up screen is plugged. How do I access the sump pick up screen ?
I have a complete shop manual from JenSales and no where in the manual does it mention or show the pickup screen in the sump.
Next problem , the power steering , with all new belts , tensioned as required , while sitting still it turns hard 1/4 turn then free 1/4 turn and so on in both directions. At low and hi idle RPM same as @ high RPM. Belts arent slipping and reservoir is at high limit with type A automatic transmission fluid.
