The 3 point will lift and lower. However it will only lift with the control lever in the all the way up position. It will hold the arms at any position with the control lever about 2" from the top. Any position below that will lower the 3 point all the way.
It acts the same with the selector lever in either position. The horizontal position points the handle straight ahead at 3 o'clock. The vertical position points the handle closer to 5 o'clock. Is that where the vertical position really is?
I understand a worn cam pin is a common cause of 3 point issues on these tractors but will it cause this issue?
