Previous owner had started installing power steering but didn't live long enough to finish it. When I got the tractor the hood was just laying in place w/o being bolted down. The gas fill access door fit was poor then, at the time I blamed that on no bolts.
Buttoning up the hood today did not help. The gaps are tight at the nose cone (those bolts were never loosened) and instrument panel yet the top panel has huge gaps and doesn't want to latch. Brake side gap is 1/2" at the front, clutch side is 1/4". Our Jubilee's hood has an 1/8" gap on both sides, I'm assuming that's what the fit is supposed to be?
By the serial # my 861 is a 1958 model, the hood sides are smooth with Ford 861 power master decals. The patina is even, I believe the hood is original to the tractor or at least all the pieces appear to be mates. Another thing, it feels like the gas cap hits on the hood when it's closed. This gas tank is supposed to be from an 881 (tractor was once crudely converted to propane) but it's my understanding all 801s use the same larger tank. I used the tank brackets that were already on the tractor but the original gas tank had been previously removed. Everything associated with the hood but the top lid fits like it should. The tin is far from perfect but all the other gaps are good..
The parts manual says 1953-57 tractors use #nca-16617-b panel assembly (Ford's term for the gas fill access door) while 1958-64 uses #310891. Are these doors noticibly different that they cannot be interchanged? That's all I can think of that would make such wide gaps. Or am I overlooking something else?
