I need a new 8ft grader blade. I can't find any used ones so will have to buy a new one. I've never bought one so I need some help. I want something that's solid built but I won't use it commercially and about 20hrs/yr at my place.
I don't need the best but I don't need junk either.
I see el-cheap-o's at $400 and "heavy duty" at $1400. Of course no spec's to compare so this doesn't mean much too me.
So what do I want too look for brand wise ?
and about what should I have to pay?
My soil is decomposed granite or pea gravel and sand with a 15% clay content and very little moisture. A 2" rock is a "big one".
My goal:
I need to remove 2" of soil from a higher area to a lower area over 2a total.
My plan is too roll part of that 2" 8ft at a time towards the low area. If I can't make the second roll then use my front loader to pick-up the row and re-spread it then continue with my 8ft blade.
I'm planning on using ripper shanks/points set at 12" spacing in front of the 8ft blade.
Suggestions?
T_Bone
My goal:
Suggestions?
T_Bone
