Scott(Ks.)
I have been putting off replacing the manifold on my 1951 8N. I put one on in the early 80s and couldn't remember if I had used steel nuts. The tractor blew a head gasket and I decided while I had the hood off it would be a good time to change the manifold. I think I probably used anti seize on the studs when I replaced it before. All four manifold nuts came off easy with just a 3/8th ratchet. success!
Now for the head bolts. I have been spraying them with ATF, penetrant, WD-40 and everything else I had laying around on the slim chance something would get to the threads. Over this week I slowly got all but two loose. Both on each side of the center bolt. I have used a rachet and a good six point socket and got nowhere. I finally gave up and used my 1/2" CP air impact. So far, no joy. I don't really want to use a big cheater bar and snap one or both of those two bolts. Any good ideas or magic chants would be appreciated.
