9700 - Loose 3-Point Pin on Right Side - Help!
Any idea if the later hook part is interchangeable with the older 9700 part? Anything that gives a tighter fitment on the splines would seem to be a good idea.
In my case, my guess is that both the torsion bar and the hook will need replacement - so I'll be buying parts one way or another.
Anybody done a "conversion" to a later design?
In order to use the newer clamp style hanger you will need to replace the shaft as well. i have done this conversion several times. Buy all the parts from a salvage yard for a 8530, 8630, 8730, or 8830. The hydraulic lift housing will need to be removed to disconnect the draft control linkage on the inside of the rear housing.
A later TW x5 series will have the updated parts as well.
