I have an Allis b with hydraulic pump I removed the pump and took it apart to see why it didn’t work, found the ball under the relief valve mis sing replaced it and the pump work’s extremely well to lift but it will not lower, when lever is in down position I would assume the control valve relaxes on the back of the detent and the oil drains back to diff, I have 3 holes in the control valve plate 2 across from each other and 1 90 degrees to them, I tried to move plate but it doesn’t move and i can see the end of the pin in one hole nothing in the other two just wondering if anyone knows anything about where the contro valve plate is positioned on control valve I am guessing the valve is not going back far enough
