Starmetal47
I have a 1956 Allis Chalmers WD45 with power steering. It's the belt driven type pump on the top leff front of the engine. The pressure discharge line on it is attached the pump, at the bottom, with a little square block (I believe brass) with a large hole in that a Banjo Bolt passes through to attach it to the pump. The steeline isn't very long and goes across the front the engine the right side where it attaches to the pressure line coming from the power steering unit on the steering shaft. The line has a flare one, I believe they call a reversed flare. At any rate I need the part number for that and it would be nice if anyone knows where I can purchase one. This information would be greatly appreciates. Thanks much!
