I don't have much hope, but I'll start here and see if it's an easy answer. I'm putting a Gleaner E engine in a Allis model D grader. I've sourced a flywheel and pressure plate which accepts the heavy duty 9 spring pressure plate. It's installed on the engine, and the engine is in the grader already. The model D trans has the starter mounted on top, and the starter has been rebuilt, and it spins fine.
My issue is that the starter gear is not engaging the starter ring on the flywheel. I'm thinking that the starter ring is too deep, and the starter is not engaging it because I have the wrong flywheel installed.
The question is - are there different starter ring locations on different flywheels? I think this flywheel is from a D17 four cyl engine, but I'm not sure. If the starter ring is supposed to be further back on the flywheel, that would indicate that my starter is not driving the bendix gear deep enough. If anyone knows a lot about the flywheel end of the WD-45, or D17, or even the model D starter setup any guesses would help.
