Another Modified power lift question
I have posted before about how our B Power Lift was modified to run a loader. I want to make sure the bottom plug is now the pressure port and what to do. The bottom plug was replaced with a bushing that has a 1/2" NPT ID hole. Threaded into that is another bushing 1/2" OD, 3/8"id that pushes a spring up. Threaded into the second bushing is a 3/8 NPT plug. If that is the pressure port, I am not sure on how to tap into it? Replace the 3/8" NPT plug with a small section of 3/8 NPT pipe or remove both the 3/8" plug and 1/2" x 3/8" bushing and replace it with 1/2" NPT pipe and just leave the spring loose in there?
