Are Brass Battery Terminal Connectors Better?
They work well. the conductivity is a bit better than lead, but there is more lead in the conventional style. A clean install, and some corrosion inhibitor and all good. Jim
I think it depends. those that I recently see that have one screw in from the side that both retains the cable and clamps to the battery post are questionable at best. I would think the first time the connection overheats you could have the connetion loosening up. The old style, with the cable retained at one place and another bolt to clamp to the battery post should be better.
I've been using them for a while now. While they aren't as good as a crimped on end, they are 10 times better than the lead repair ends. The brass ones will actually clamp down on the cable and hold it unlike the tin strap on the lead ends.
I've found them harder to clean and harder to get to clamp tight to a battery post. I much prefer the lead type easy to clean and easy to get to clamp down tight
I can do better so don't use a emergency repair ends and thats what they are. I have never used them I have replaced some when they broke while cleaning up are replacing a battery. They are brittle and don't take to resizing well. In the lead option they make a positive and negative end to properly fit the post do they have that option on those.
The group 31's with the stud work the best o folling around with cleaning all the time and no warped over tightened clamps to deal with just screw the nut down tight and go. I do clean them any time I have them off. And connecting monitors to the batteries is easier with them too.
Whatever you do, don't use the ones that clamp the cable ends like those. Get the stud type and crimp terminal ends on the cables.
AaronSEIA
I just had a battery terminal episode on my antique car on Monday. I replaced a bad alternator, and when done I started it and everything was fine. I shut it off, and when starting again a few minutes later I had major arcing. It turned out that when I had cleaned the lead positive terminal a few days earlier, I hadn't gotten it tight enough. When I clean them I I use my pocket knife to remove some lead from the inside to make it mirror bright. After this episode I had decided to upgrade, and when at a cruise nite that evening I noticed that the popular set-up is now billet aluminum terminals. Numerous cars have them. I may go with brass but either way I will be installing crimp-on terminals which I really should have done long ago.
Opening the link posted would have answered that question.
I think the major cause for battery terminal failure is wet cell batteries that produce acid fumes.
No terminal failure on AGM batteries.
Ugh! Parts man's best friend. They'll get you from the field/side of the road back to the shop where you can fix it. I always told my farmer customers if I sold more new cables, I wouldn't sell nearly as many batteries, alternators, and starters...
Which post are you referring to?
Depends on who installs them. Some guys can’t handle a simple operation like this. Soon it’s all corroded and have a no-start condition. Not the fault of the repair end.
