Tree-Farmer
I'm trying to plow a pasture and having a couple of problems that I would like to ask you about. I have a 986 and a new used 710 plow.
1. One side of the 3 point hitch keeps coming out. (not all the way, just 6 inches) Can you tell me why this is happening? I'm guessing that something is worn. If so, what is the worn part? Is it the top part with the ring that you can lift up?
Can I tie this down? Maybe put a wire through the ring and tighten it down, to hold it in place, keep it from coming up?
Or should I buy a new clip on the 3 point hitch? What's it called?
2. I pulled the pin to let the 3 point hitch swing from side to side, but it keeps hitting the tire on the left side, when I turn. Why does one arm on the 3 point hitch hit the tire?
I'm thinking that I need to screw in the bolt/holder/connector on the inside of the arm. What do you think?
I should be able to take the pin out and turn the square end piece, I think.
By the way, my 986 pulls a 5 bottom plow easily in 3rd gear in Missouri clay soil. I should have bought a 6 bottom.
