I have a B with a C rear end, use it for snow plowing. This weekend I had a chance to pick up a center mount mower for reasonable. I don't need it, don't hay and live in woods, but it was reasonable and orange so it is in the yard now. It has front mounting brackets that look like they can bolt on to the mower frame in two positions to mount on B, C, or the longer wheelbase CA. Anyway it came with both rear drive pulleys however the spline on the upper one is 1 3/8, and doesn't fit the one on my C rear end which is (I think), 1 1/8. The mower was supposed to have been used on the B the guy I bought it from had. Possibly the CA had a larger PTO shaft then the B, Cs. Also the pulleys are double sheave and B,C mowers I have seen are single. The double sheaves are smaller dia. than I remember too. Can anyone shed some light on what I ended up with. Does anyone have a pulley to fit the smaller PTO shaft? As I said, not desperate, but maybe someday it might be fun to mount it up especially if some use came along for it. It seems to be in pretty good shape with the exception of the inside pitman rod end which has been run loose on the bearing but I think my brother has on on a parts mower he has but I don't think he has a PTO pulley. Thanks, Tom
