Working on my '49 B yesterday. I've got some starter issues I'm working on (bendix keeps kicking out). Anyway, it sat outside for a few days and it got rained on one night. Not an issue to me but some people like to keep them in or have the mag covered. So I started it up and could tell it wasn't running right. I pulled the top mag wire and no change in the way it ran. Pulled the bottom wire off and it wanted to die on me. So I'm assuming it's not firing on the right side!? Figured the mag probably got wet and has a problem. But when I went to pull the plug boot off I got a shock through a crack in the boot...it's not the correct right angle boot and its cracked where it's kinked. So, I've got juice there. Put an inline test light between the plug connection and the plug and the mag appears to be firing OK. So I thought maybe I had a bad plug...took both plugs out, cleaned them, but when I put them back in I swapped them out side to side. Still no change on the right side when I pull the mag wire. Am I looking at things correctly here?? Any thoughts? I will replace the plugs/plug wires anyway.
