I have a 1945 2n serial # 158xxx, 12v and I am trying to complete a rebuild of this tractor and have many issues with the machine shop. I recently had to return the oil pump and have the shop re-do it's work and now it seems to be working fine. As I didn't have all the measuring tools to do the job and he did. Then I had to remove the engine once more when I noticed none of the nuts on the main bearings and connecting rods had cotter pins or safety wire installed. I also replaced the front and rear seal because they were cut too short and there was not enough sealant on the ends of the rope seals. I also replaced all the cylinder head studs and nuts along with the head gasket with copper gasket spray. While I was there I put the oil slinger and camshaft locking ring. ( Thanks to those who helped me identify the correct ones to use) Then correctly installed the water pump.
So before I installed the head back on I manually rotated the engine via the hand crank and noticed that No.s 2 & 3 cylinder sleeves moved in and out of there cylinder, before they fell out I pushed them back into the block. Can I repair this without removing the engine again? Or is this going to require the engine being split once more? Out of frustration I bolted the head on as the gasket was sprayed already and it kept me from looking for a sledge hammer until I cooled off a bit. Thinking all I needed was one person to do his job correctly and that's not what I have. So after almost two weeks of doctors and tests I now am back at the task of getting this tractor back in running shape before I lose one more season of work that is not going away.
So the cylinder sleeves any suggestions?
Just a side bar on the pictures below, in the second picture of the 9n/2/ wiring drawing by JMOR, why would a person leave the better part of the electrical system energized? As I see that the positive is connect straight from the cut-out relay to the resistor block energizing anything connected to it 100% of the time. Hopefully there is a switch of some sort keeping this energy from frying something out.
I noticed this when I installed a new oil pressure gauge and it had a light in the dial. Not knowing where to properly install this light I connected it to the bottom post of the resistor block and it would be on 100% of the time, so I just omitted the light all together. In retrospect I believe it should have gone to the light switch. But this didn't answer the question of Why leave a hot wire thru the ammeter to the alternator. I now see that this should be a second post.
Thank You for your time spent helping me get through this., William
