Greetings, I have had a 1963 Ford 3000 selecto shift tractor for about 15 years. Last March when grading our farm lane the transmission filter gasket blew out. Assuming an old gasket with loose bolts, I replaced the gasket, filter and torqued properly. Upon start up, same thing, blown gasket. I towed it to our shop, and with the service manual as a guide, removed the transmission cover, upper trans manifold, and checked the alignment of the selector shaft. I disassembled and cleaned the manifold and I also checked the main pressure tube from the filter to the manifold. Same issue, the filter gasket keeps blowing. Apparently there is a blockage somewhere not mentioned in the service manual. Any ideas out there???
