Bolts used with little genius plows
Charlie M
Can someone tell me what type of bolts are used on the mold boards of a little genius plows. Regular plow bolts that is sold today don't work.
Are they "clipped head plow bolts"?
Not on my little genius. I'm wondering if someone may have "updated " something, mine just takes regular plow bolts.
There is the possibility that the part is so worn out that a new plow bolt sits above the surface.
IH made a multitude of different plow bottoms. Any of them from at least the earliest bottoms on a little genius to the super chief interchanged (as long as you used the same size). The purchaser of a new plow could choose any style bottom. So referring to a plow bottom for a little genius tells you it is IH but is about meaningless beyond that. You need to identify the bottom.
If you are just looking for bolts, you should be able to source them by the type head and size. If you don't know what the head is, post pictures.
i would say this is a case of a picture tells the story of what your looking for. all kinds of plow bolts out there.
