So, for a plow, I get that you put the top link in the top hole of the rocker and set the 3 point to draft control. However, i don't know how to use the other two holes. My only other implements using the 3 point is a brush hog and back blade. My disk is a pull behind.
I know I should run the 3 point in position control with the brush hog. The question is where to set the top link when using a brush hog. I have been running it in the center hole and using stabilizer bars. I am adding limiter chains so wondering where they attach at the top end? Do I keep the top link in the center hole and attach the chains to the same pin or attach the chains to the lower hole?
I assume the back blade is set up the same as the brush hog.
BTW, unfortunately the stabilizer bars won't also fit on the brush hog pins once I put the chains on. I guess I could get longer pins but wondering if the chains will also act as stabilizers anyway.
This post was edited by Orion231 on 07/25/2022 at 08:01 pm.
