farmallboy15
Farmall 706 PTO was working fine one day, went out the next and nothing. Just pulled the control valve bottom plug. The little pin is definitely sheared off. Based on the diagram, it looks like the upper valve portion didn’t come out. Tried popping the lever up and down a couple times.
Am I reading the diagram right, I’m missing a part? If so, what’s the trick to get it out for pin replacement?
Is that a part of the upper mechanism and I need to disconnect it on the outside for it to fall out?
Item #26 is the one in question. 27 is the new pin I bought sitting on the towel.
