Case 400b revisited here are some pictures of the tractor.
Case 400b revisited here are some pictures of the tractor. The gears grind quite a bit. It sounds like you have to start out in gear with the clutch down. What size tires do you think it has? The left rear rim needs replaced. It leaks oil out at the starter. The lift will not go down, when the lever is pushed down. I still haven't seen the tractor in person. Thank you fellow J.I. Case enthusiasts
