Anonymous-0
Hi, I recently acquired a Case 530 CK loader/bhoe with the gas engine. It is in pretty good condition however on using it I've noticed that the two levers for the bucket/dipper aren't balanced so when you pull them both back with the bucket teeth in the ground horizontally, the bucket will rapidly start scooping while the dipper takes forever to pull forward. Plus moving the boom up and down causes the machine to jerk and bounce which seems to be too much pressure. The loader doesn't seem to have enough power to lift a load unless you throttle up to 2600 rpm. Is this normal with this machine or should everything be as smooth as a new 580. Any links or tips on whats involved in balancing the pressure for the loader and the hoe?
