Hi all, I am trying to separate the transmission gear "cage" from the rear axle on a 530CK backhoe from the 60's. I have a compiled Case manual that shows separating the axle from the torque tube and then jumps to disassembly of the gearing from it's "cage". The manual states remove the gear assembly from the axle assembly (more or less) but doesn't break it down clearly and mine doesn't want to let go after what appears to be everything holding it together addressed. Anyone here have some helpful info per chance?
(Notes: the only thing that seems to be left holding things together is a roll pinned collar on the axle housing side of the cage. Also, for clarity sake the cage I am referring to is the cast iron cube(s) that the drive gearing is assembled into)
