CasevsDeere
As with any good project the more you open up, the more problems you find. Started just replacing the brake seals so I could get good brakes and found the classic bearing race pitting from water sitting in the bottom of the cup/cone. There does not seem to be much info out there regarding changing these bearings so I figured I would document this project here for others who may be looking for info.
Hoping that I can sneak a puller through the housing and remove the cone bearing, otherwise I will need to take the drive chain loose to get the differential shaft out, which I am sure will snow ball into an even bigger project.
