Email me. I’m real person
I recently changed the oil on my Case 430 TLB and now I can’t get it to start. I checked the battery and that’s not it. I tried ether going into the air filter (which helped it start when needed before the oil change) and still won’t turn over. Sometimes it is SOO close to starting, but just won’t.
There was not much oil to drain out and it was definitely black. Also, there was no oil in the bottom cup of the air filter like the manual says it should have. I corrected these issues, but it started fine with an occasional blast of ether before!!!
It did start eventually after hours of trying (jump starting battery, bypassing battery jumping the starter, trying both 10 ga and 6 ga jumper cables, checking connections, replaced a couple wires, etc.), and it ran completely fine without issue. But after a few hours of use it started blowing some white smoke out the bottom of the machine. I shut it off for 30 minutes or so and now it won’t start again.
I can’t imagine it’s an issue with the oil or filter. Any other ideas? Glow plugs??? I did use full synthetic as it was on sale for less than the others, but that shouldn’t be a problem, right?
