Hey everyone. New member here. We purchased some property about a year ago that had an old Clark forklift that came with it. I believe it was running when parked (probably 10+ years ago) as it was replaced for an electric forklift. Anyways, we dug it out in hopes of getting it running again. We were not able to to find any ID tags on the forklift or engine for that matter, but after some research it appears to be a Continental Flathead 4 cylinder. We replaced the battery and got a tank of propane and tried to start. It would turn over great, but nothing. No apparent spark. So, we replaced the points and condenser, spark plugs, coil and still no spark. We then replaced the the Delco Remy cap (clip style pre-1963) and rotor and tried again. No spark yet. The plug wires seem to be okay and I've check for continuity.
The engine is very rusty, so I thought maybe the spark plug wasn't grounding well enough. I tried several other areas and still no spark. I took a plug wire and attached it directly to the rotor and then tried to get spark from that and nothing. This is a generator 12v setup. I checked for 12 volts at the distributor stud that has a wire connected to the one side of the coil. With key turned and start button held it does have 12v at this stud while cranking. I also spread apart the points with a screw driver while cranking engine and I DID see sparking there and they do open and close.
So, at this point I'm not sure what to try or check next. The rotor does point towards cylinder 1 and wasn't apart or anything and was previously running when parked, which leads me to believe the timing should be fine. I just have no spark. The only thing I haven't changed are the spark plug wires, but they do look like they were replaced at sometime and I don't see any obvious reason to do so.
Any help would be great. I can provide pics or additional information if needed. Thanks, Jason
