TractorBob
Hi, my brother rebuilt a Farmall Cub Loboy early 60's. Did Values, put on new standard rings, and head gasket. He huckleberry the cylinders. The motor ran for awhile and then cylinders began to loose compression. I took the head off and checked the cylinder size. Took 4 measurements at top and 4 at bottom. Measurements range from 2.627 to 2.629. According to the manual that should still be within acceptable spec. He used standard rings and the ring gap at the bottom of the cylinder is .012 and .024 at the top. Manual calls for .007 to .017.
He does not want to pay for a rebore. Looking for suggestions on what to do next. Is the bigger gap in the rings that big a deal? This is my first time doing this so any input would be helpful.
Thank You Bob.
Thank You Bob.
