Converting to Electronic Ignition - IS OEM IGNITION SWITCH SUFFICIENT??
RTR
Of all of the Farmall Tractors I've owned and restored over the last 20 years, I'm finally going to convert one I want to keep to electronic ignition. I need to install a new ignition switch and since I'm doing the conversion, I wanted to make sure the OEM style switch will work with the EI components. This is a 1969 Farmall 140 with a 12 volt alternator conversion. The OEM switch is the one pictured. Just a simple on/off key switch that will turn the ignition module/breaker points on/off.
Of all of the Farmall Tractors I've owned and restored over the last 20 years, I'm finally going to convert one I want to keep to electronic ignition. I need to install a new ignition switch and since I'm doing the conversion, I wanted to make sure the OEM style switch will work with the EI components. This is a 1969 Farmall 140 with a 12 volt alternator conversion. The OEM switch is the one pictured. Just a simple on/off key switch that will turn the ignition module/breaker points on/off.View attachment 97827
It should work fine. I have SMTA farmall that I converted as well as a JD 430, used original switches in both.
