In my seemingly neverending saga with the 256 rake... The cotter pins that hold the dogs (part 13 in this case) into the hub assembly (part 12) are impossible to access to bend when installing new. From what I can tell, the spindle and driving hub (parts 6 and part 12 are "not separately serviced" according to the manual, whatever that means) must be removed in order to access the cotter pin from the back of the driving hub assembly so the pin can be properly bent to hold the dog, spring, and rivet in place. Any ideas how that would be accomplished? I see no cotter pins or anything else holding that hub piece in place. Wheel and wheel hub (part 16) are removed, as are rivet, spring, and dog. I'm just trying to get everything back together after servicing.
There's not enough room to get behind that driving hub (part 12) to bend that cotter pin as long as it's on the rake. The prior cotter pin had have been installed with everything removed when the rake was being assembled. That's the only way there's clearance to get it even through the rivet, much less get it bent back around it.
Thanks in advance for any helpful replies. Hoping to get this rake back together before rain comes next week.
